Chain Posted October 11, 2020 Report Posted October 11, 2020 ; Oper Tools for TheArkNet ; by Raccoon 2019 ; This script assumes that opers are not subject to excess flood disconnect. ; You can access this tool from menu by right-clicking the channel chat area. ; Actions are logged to operclosechan.log ; Example: /operclosechan #badchan You guys are misbehaving! ; /OperCloseChan <#channel_name> <reason_required> ALIAS OperCloseChan { var %chan = $1, %reason = $2- if (!%chan) { echo -atic notice * Usage: /OperCloseChan #channel_name This channel is closed due to violation. | return } if (!%reason) { echo 4 -ati * OperCloseChan: You MUST specify a reason for closing the channel! | return } if ($left(%chan,1) !isin $chantypes) { echo 4 -ati * OperCloseChan: %chan is an invalid channel name! | return } if ($me !ison %chan) { set -eu10 %_operclosechan. $+ %chan %reason !JOIN %chan return } ; ----- MSG %chan This channel has been determined to be in violation of the terms of service for this network and is being closed. $& If you have any questions please join #Help and speak to an IRCop. (Reason: %reason $+ ) CS CLEAR %chan USERS CS CLEAR %chan BANS CS DROP %chan %chan MODE %chan +muski $regsubex(randomstring,$str(x,10),/x/g,$r(a,z)) PART %chan echo -stic info * OperCloseChan: Closed channel %chan for %reason write operclosechan.log $asctime %chan %reason } ; by Raccoon 2019 ; End of /NAMES (you joined a channel) RAW 366:*: { var %chan = $2 if ($($+(%,_operclosechan.,%chan),2)) { unset $+(%,_operclosechan.,%chan) OperCloseChan %chan $v1 } ; ... } ; by Raccoon 2019 MENU Channel { - Oper Tools .Close Channel: { OperCloseChan $& $$input(Enter channel to permanently close.,ews,$active,Oper Tools: Close Channel,$active) $& $$input(Enter reason for closing the channel.,ews,$active,Oper Tools: Close Channel) } ;... } ; by Raccoon 2019 ; eof
Administrators Koach Posted October 11, 2020 Administrators Report Posted October 11, 2020 Thanks, Chain. I learn a lot from studying scripts like this.
