Stormy Posted June 15, 2020 Report Posted June 15, 2020 Here's what a color popup should look like with mirc 2(((4(((7(((8((((12(((13(((4 $1 13)))12)))9)))8)))7)))4)))2))) The blocks are the CTRL codes for the colors, which run from 0 to 15 $! represents the first word you type after typing the aias trigger, so the actual popup in Aliases would look like this: /hugc 2(((4(((7(((8((((12(((13(((4 $1 13)))12)))9)))8)))7)))4)))2))) So copy and paste that line in aliases, click OK to save, then type /hugc name in a channel. EDIT: The blocks didn't show, before each number, you must press the CTRL key, Press CTRL+K then the #, then release both. CTRL+K for color, CTRL+B for bold, CTRL+I for italics and CTRL+U for underlined text.
