Stormy Posted July 6, 2018 Report Posted July 6, 2018 (edited) Steps to Registering a name. 1] To register your nickname type: /ns register your_password your-email Make sure to use a valid email, so nickserv can send your password if you forget it. (make sure you are using the name you want to register. 2] If you're told to identify your nickname with nickserv type: /identify your_password. Steps to Registering a Channel. 3] To register a channel, you must be in the channel you wish to register and you must be +o, not +q or any other level. Are you in that channel? If not join it by typing /join channel_name. 4] OK, now type this: /cs register #your-Channel-name your-password description [this is just something about what the Channel is to be used for and is not really needed. Steps to Adding a service bot to your registered channel. 5] To add a service bot, first you must decide which bot you want: Type /bs botlist and it will show you a list in your status window. 6] When you decide which one: this can be typed in any screen: /bs assign #Roomname Bot_Name 7] After it's in the Channel you'll want to add some commands. One I highly recommend are Fantasia. To set Fantasia type /bs set #Room_Name fantasy ON . 8] BOTSERV commands are here 10] Info on using ACCESS to set levels is here , a channel and adding a service Bot to the channel Edited July 6, 2018 by Stormy Added some and fixed errors
