charles256 Posted February 11, 2012 Report Posted February 11, 2012 Hello I wrote the following script for Koach.com To install the script: Open mIRC.exe Press Alt+R to open the mIRC Scripts Editor Copy and paste the script Click OK To use the script: Please read the comments in the script for how to use :-) -------------------------------------------------------------------- /* { "birthday" by Charles "charles" M. (February 2012) # Prelude Koach (a hacker) put a list of birthdays (name month/day) on the Koach.com forum. # What does this script do? This script attempts to connect to the Koach.com forum to retrieve the list of birthdays. It then compares each birthday to today's date. If there is a comparison, it will notify you with the user's birthday. # How do I use this script? The script can be used in two ways: Alias: birthday or Popups: Status Window or Channel Window -> Birthday -> Check for Birthdays # How do I contact you? charles @ irc.koach.com # Version history 11/02/2012 First public release. } */ /* ** ** Aliases ** */ ; _echo [-eiw] <text> ; Prints text in the active window using the optional colour switch. ; ; The colour switches are as follows: ; ; -e -- error ; -i -- information ; -w -- warning alias _echo { if ($0) { var %colour, %switches if ($active == Status Window) { %switches = -cegs } else { %switches = -cga } if (-* iswm $1) { if (e isincs $1) { %colour = "ctcp text" } elseif (i isincs $1) { %colour = "info text" } else { if (w isincs $1) { %colour = "wallops text" } else { %colour = "info text" } } tokenize 32 $2- } else { %colour = "info text" } echo %switches %colour * $1- } } ; birthday ; alias birthday { if ($sock(birthday)) { sockclose birthday } set -e %birthdays 0 sockopen birthday www.koach.com 80 .timerbirthday -o 0 28800 birthday if ($show) { _echo -i Connecting to birthday server } } /* ** ** Popups ** */ menu status,channel { &Birthday .&Check for Birthdays: { birthday } } /* ** ** Events ** */ on *:START: { if ($version < 7.22) { _echo -e birthday is designed for mIRC 7.22. It should work on your $& mIRC version $+($chr(40), $version, $chr(41)) but it is untested $& and may act strange. } birthday } /* ** ** Socket events ** */ on *:SOCKOPEN:birthday: { if ($sockerr > 0) { _echo -e Error while connecting to birthday server return } var %% = sockwrite -n birthday %% GET /forum/index.php?/topic/328-current-birthday-list/ HTTP/1.1 %% Accept: */* %% Host: www.koach.com %% Connection: close %% } on *:SOCKCLOSE:birthday: { if ($sockerr > 0) { _echo -e Error while disconnecting from birthday server return } } on *:SOCKREAD:birthday: { if ($sockerr > 0) { _echo -e Error while reading data from birthday server return } var %data sockread %data while ($sockbr > 0) { tokenize 32 %data if (HTTP/1.?* iswm $1) { if ($2 != 200) { _echo -e Error while connecting to birthday server sockclose birthday } } elseif (*cached*Date Nick* iswm $1-) { sockmark birthday 1 } else { if ($sock(birthday).mark) { if ($regex(birthday, $1-, /0?(\d+)\/0?(\d+)\S*([^<]+)/)) { if ($+($regml(birthday, 1), /, $regml(birthday, 2)) == $asctime(m/d)) { beep inc %birthdays _echo -w It's $+($regml(birthday, 3), 's) birthday! } } else { if (*</div>* iswm $1-) { sockmark birthday _echo -i Finished checking for birthdays. Found: %birthdays unset %birthdays } } } } if ($sockname) { sockread %data } } } ; EOF
Administrators Nan Posted February 11, 2012 Administrators Report Posted February 11, 2012 Wow that looks very interesting, I assume you have tested it and it all works perfectly (or you wouldn't have put it here) .. thanks charles
Administrators Koach Posted February 19, 2012 Administrators Report Posted February 19, 2012 Thanks, Charles I can't wait to try it out Signed, "a hacker"
Administrators Nan Posted February 19, 2012 Administrators Report Posted February 19, 2012 LOL - and it works !!!!!!!!
Crysta Posted February 19, 2012 Report Posted February 19, 2012 I have it loaded and it works great! Thanks
Crysta Posted February 19, 2012 Report Posted February 19, 2012 yesterdays: * Connecting to birthday server - * It's code's birthday! - * Finished checking for birthdays. Found: 1 Todays * Connecting to birthday server - * It's Crysta's birthday! - * Finished checking for birthdays. Found: 1
