BotServ allows you to have a bot on your own channel.
Available commands are listed below; to use them, type /msg BotServ command.
For more information on a specific command, type /msg BotServ HELP command.
BOTLIST - Lists available bots
ASSIGN - Assigns a bot to a channel
SET - Configures bot options
KICK - Configures kickers
BADWORDS - Maintains bad words list
ACT - Makes the bot do the equivalent of a "/me" command
INFO - Allows you to see BotServ information about a channel or a bot
SAY - Makes the bot say the given text on the given channel
UNASSIGN - Unassigns a bot from a channel
The Bot will join a channel whenever there is at least
1 user(s) on it.
For additional botserv commands: Click here
Crysta
