Guest ajaX Posted December 29, 2011 Report Posted December 29, 2011 Premise After the slew of hurricanes and tropical storms that plagued the east cost this year, I think just about everyone became aware of 'flooding basement syndrome'. And, in accordance to Murphy's Law, the flooding MUST begin at 3am when you are soundly asleep in bed then continue to flood until you wake up the following morning to a brand new indoor pool. The second night is even better. You've learned your lesson and you're prepared for the worst. Unfortunately, all this results in is you standing there at 1am staring at a sump pump float for hours, performing your own scientific field test of the adage 'what goes up....must come down' and each time praying that it does. What you'll need A battery operated smoke detector ($7) a large PVC coupler ($6) a large sponge ($1) A SPST switch ($1) wire a soldering gun glue How it works It's pretty simple and should only take you a good 30 minutes to put together. Basically, your highjacking the 'test button' that's present on any smoke alarm by attaching to leads to the PCB that go down into a sponge that's at ground level. When water saturates the sponge it completes the circuit causing the alarm to sound (and yes, the smoke detector still works too). Start by drilling a hole in the side of your PVC coupler to accommodate the switch Mount the switch in the PVC coupler Using a dremel, cut out sections at the bottom of the coupler to allow water to flow in instead of around it as it's sitting on the floor Cut the sponge to fit in the bottom section (snugly) of the PVC couplerthe smoke detecto Disassemble the smoke detector Remove the battery and the PCB (you'll probably have to remove some battery clips as well) On the PCB, find where the test button is (long flat piece of metal) Flip the PCB over and find the two leads that correspond to the test button. Solder a wire to each one Run one of the wires to the switch then prepare another longer wire to run through to the bottom Run the other wire coming from the PCB through to the bottom Strip a healthy section of insulation off the tips and apply solder At this point you probably want to touch the two leads together for a few seconds to ensure everything is working properly (make sure your switch is in the 'on' position). If so, you'll be greeted by that all too familiar screech, if not your wiring is incorrect. If all is well, place the smoke detector in the top section of the PVC coupler and push each soldered lead through the sponge so that the ends are no more than an inch apart and just sticking out of the sponge. Once tested, glue the smoke detector in place. That's it! Test it by putting it in your sink and filling it up with water. The switch allows you to turn it off once you've had a successful alarm (otherwise, it'll just keep going until the sponge dries out enough to lose the connection). (DIY bought to you by: Thomas Clauser)
Administrators Nan Posted December 30, 2011 Administrators Report Posted December 30, 2011 Love it !!! However as I'm at almost 3000ft in the mountains, I am more likely to need a fire alarm than a flood alarm. But for people in flood areas that's really interesting, thanks !!
