Zimri Posted February 3, 2011 Report Posted February 3, 2011 on *:NOTICE:*:*: { if (Nickserv!*service* iswm $fulladdress) && (Koach.com == $network) && (*nickname is registered* iswm $1-) { identify ********** } } put the above in remotes and do the following ********** <---- replace that with your password
X-Fusion Posted February 3, 2011 Report Posted February 3, 2011 Personally, I use mIRC's perform feature. It works as an on connect feature. When you connect to the server, it performs your input. To access it, do the following: Navigate to 'Tools' in your menu bar, from there select options. If you like shortcuts (which I do), just use Alt O From there, click the plus next to 'Connect.' This will expand to a sub-menu After that, select Options which is the second choice in the sub-menu Within the Options selection, you'll see a button titled 'Perform..' Click that. Check the box that says 'Enable perform on connect' In the text area labeled 'Perform commands,' enter in the commands you want to perform. I like to make sure my nickname is ghosted if I'm ever disconnect it so I can easily recover it. My perform looks like this: /timer 1 1 ns ghost my_nick my_password /timer 1 3 nick my_nick /timer 1 5 ns identify my_password Pretty easy, basic stuff, but not a lot of people know about that feature. You can do any number of things when you connect.
Morph3us Posted April 10, 2013 Report Posted April 10, 2013 I added a raw to it to kill a ghost on *:NOTICE:*:*: { if (Nickserv!*service* iswm $fulladdress) && (Koach.com == $network) && (*nickname is registered* iswm $1-) { identify ************* } } raw 433:*:{ .nickserv ghost YOURNICKNAMEHERE ********** .Nick YOURNICKNAMEHERE } ***************** is where your pasword is
Chain Posted April 3, 2020 Report Posted April 3, 2020 on *:load:{ set %email $$?="enter your email address" set %nspass $$?="enter your nickserv password" set %dnick $$?="enter your default nick" echo -a 6-=- Your Default Password Is: %nspass 6-=- echo -a 6-=- Your Default Email Is: %email 6-=- echo -a 6-=- Your default Nick is %dnick 6-=- nick %dnick } on *:start: { nick %dnick } Menu * { Nickname .Register Nick ..Register: /msg nickserv register %nspass %email ..Group Nick: /msg nickserv group %dnick %nspass ..Check Info: echo -a 6-=- Your Default Password Is: %nspass 6-=- | echo -a 6-=- Your Default Email Is: %email 6-=- | echo -a 6-=- Your default Nick is %dnick 6-=- ..Change Info ...Change Pass: set %nspass $$?="enter your nickserv password" | echo -a 6-=- Your Default Password Is: %nspass 6-=- ...Change Email: set %email $$?="enter your email address" | echo -a 6-=- Your Default Email Is: %email 6-=- ...Change Default Nick: set %dnick $$?="enter your default nick" | echo -a 6-=- Your default Nick is %dnick 6-=- .Ghost Nick: /msg nickserv ghost %dnick %nspass | .timer 1 3 nick %dnick .Auto Identify ..On: enable #autoid ..Off: disable #autoid } on *:NOTICE:*Your nick* isn't registered*:*:{ if ($me == %dnick) { .timer 1 3 echo -a 6-=- Your Nickname Is Not Registered On This Server: $server 6-=- } if ($me != %dnick) { msg nickserv info %dnick all if (Time registered isin $1-) { .timer 1 3 echo -a 6-=- Your Default Nickname %dnick Is Registered On This Server: $server 6-=- } if (isn't registered isin $1-) { .timer 1 3 echo -a 6-=- Your Defalut Nick %dnick And Current Nick $me Are Not Registered 6-=- } } } #autoid on on *:connect:{ /msg nickserv identify %nspass } #autoid end
Administrators Koach Posted April 13, 2020 Administrators Report Posted April 13, 2020 That looks like a pretty handy script. Thanks, Chain
