foreverurs said: ChanServ Command Center(Dialog)
Jan 1st, 2009, 6:23pm
Hi everyone :D
This dialog is designed to make the use of ChanServ a little easier
heres what you have to do in order to use this
step 1) in your mIRC type //echo $mircdir
step 2) Extract dcx_v1.4.0.zip into the folder that $mircdir returns
step 3) load the following 3 files into the scripts editor
Csdpi96.txt
dcx.mrc
dcx_tools.mrc
the dialog has no buttons its all right click menus
I think some of you will find this makes the usage of ChanServ commands much faster and easier
i hope you enjoy this add-on
if you find any bugs or anything please let me know :D
you have to have ChanServ access (i.e Founder/Access/xop) in order for all the commands to work
some commands are only allowed to be used by the Channel Founder
here is one picture of the one i use, the version in this post has captions above the listviews to let you know what each one is
http://i39.tinypic.com/2ensto3.jpg
BUGS FOUND TO DATE
there was no menu in the access listing to remove a user from sop aop hop or vop BUG FIXED
also adding to vop from the access listview actually adds to hop BUG FIXED
dcx_v1_4_0.zip
  • 1 year later...
