Updated 12/22/2016
For these commands to work, you must tell botserv to set FANTASY ON for your chat room.
/bs set fantasy #RoomName on
Supported Commands:
Available commands are:
     ACCESS                 Modify the list of privileged users
     AKICK                     Maintain the AutoKick list
     AOP                        Modify the list of AOP users
     BAN                        Bans a given nick or mask on a channel
     CLONE                   Copy all settings from one channel to another
     DEHALFOP             Removes HALFOP status from you or the specified nick on a channel
     DEOP                      Removes OP status from you or the specified nick on a channel
     DEOWNER             Removes OWNER status from you or the specified nick on a channel
     DEPROTECT          Removes PROTECT status from you or the specified nick on a channel
     DEVOICE                Removes VOICE status from you or the specified nick on a channel
     DOWN                    Removes a selected nicks status from a channel
     ENFORCE              Enforce various channel modes and set options
     ENTRYMSG            Manage the channel's entry messages
     FLAGS                    Modify the list of privileged users
     GSTATS                 Displays your Global Stats
     GTOP                     Displays the top 3 users of the network
     GTOP10                 Displays the top 10 users of the network
     HALFOP                 Gives you or the specified nick HALFOP status on a channel
     HELP                      Displays this list and give information about commands
     HOP                        Modify the list of HOP users
     INFO                       Lists information about the specified registered channel
     INVITE                    Invites you or an optionally specified nick into a channel
     K                             Kicks a specified nick from a channel
     KB                           Bans a given nick or mask on a channel
     KICK                       Kicks a specified nick from a channel
     LEVELS                  Redefine the meanings of access levels
     LIST                        Lists all registered channels matching the given pattern
     LOG                        Configures channel logging settings
     MODE                     Control modes and mode locks on a channel
     MUTE                     Bans a given nick or mask on a channel
     OP                          Gives you or the specified nick OP status on a channel
     OWNER                  Gives you or the specified nick OWNER status on a channel
     PROTECT               Gives you or the specified nick PROTECT status on a channel
     QOP                        Modify the list of QOP users
     SEEN                      Tells you about the last time a user was seen
     SOP                        Modify the list of SOP users
     STATS                    Displays your Channel Stats
     STATUS                  Find a user's status on a channel
     SUSPEND              Prevent a channel from being used preserving channel data and settings
     SYNC                      Sync users channel modes
     TOP                        Displays the top 3 users of a channel
Let me know if you have questions
  • 6 years later...
I assigned the bot ( Chat_Bot) in a dutch room (#30-60) , all the chatters including the founder uses webchat and they have selected colored and sometimes bold font.
The bot reacts on !up and !down with this colored font , other commands like !k and !devoice etc dont work with these colored fonts.
If i set the font to standard ( no color and not bold or underlined ) all the commands work perfectly.
Can someone look into this , dont hurry though :)
Casa
  • Casa featured this topic
You could try room mode +S (/mode #chan +S)
That should strip mIRC color codes.
I have tried that but chatters want to use colors in their messages , and even then it doesnt react on most of the remote commands except !up and !down.
If i use mode +S than u see only black text and it works but if the chatter uses Bold , Underlined or Background Color  it wont work .
Weirdest thing is that Up and Down commands works all the time only the rest doesnt work with other than black Not Activate Foreground Color , Bold and Underlined.
All the text has to be stripped from color , bold , underlined and other stuff before processed further in the bot.
  • 5 years later...
