Administrators Koach Posted January 24, 2011 Administrators Report Posted January 24, 2011 How to use LEVELS to set custom levels As explained here: http://www.koach.com/forum/index.php?/topic/268-auto-q-works-again/ once you have disabled the XOP lists system, you may assign levels to users in your channel. However, you may also customize the channel LEVELS. For example, suppose you only wanted to allow users with a 9999 level to be able to set room TOPICS. To do this you would type: /cs levels #roomname set topic 9999 From then on, only users set to 9999 or higher (Founder) would be able to change the room topic. For more information about LEVELS type: /cs HELP LEVELS and /cs HELP LEVELS DESC Koach
