Spike posted a simple remote script for a p2p block which was very great.
this is my version of a p2p block. Basically what i have is a dialog that lets you add users to a list of people who are allowed to p2p you. If the users are not on the list and they p2p you when the blocker is on they will get an auto message and it will count how many p2p's youve blocked since its been on
hopefully someone can find it useful
menu * {
p2p block:/dialog -m p2p p2p
alias p2p { dialog -m p2p p2p
dialog p2p {
title "P2P Blocker"
size -1 -1 160 70
option dbu
button "Block", 1, 86 8 33 13, flat
button "Allow", 2, 123 8 32 13, flat
box "Exception List Options", 3, 84 23 73 42
button "Add", 4, 88 33 32 12
button "Spam", 5, 122 33 32 12
button "Remove", 6, 88 49 32 12
button "Done", 7, 122 49 32 12, cancel
box "Exception List", 8, 5 5 75 60
list 9, 10 13 66 50, vsbar
on *:dialog:p2p:sclick:1: {
if (%p2p == on) { noop $input(P2P block is enabled,uwo,Error!) | halt }
set %p2p on
amsg P2P is now blocked for security purposes
on *:dialog:p2p:sclick:2: {
if (%p2p == off) { noop $input(P2P block is disabled,uwo,Error!) | halt }
set %p2p off
amsg P2P is now being accepted
on *:dialog:p2p:sclick:4: {
var %p2pallow $input(Enter a nickname to add,e)
if (%p2pallow == $null) { halt }
if (%p2pallow == $read(p2pallow.txt,w,%p2pallow)) { noop $input(%p2pallow is alread in the exception list,uwo,Error!) | halt }
write p2pallow.txt %p2pallow
did -a $dname 9 %p2pallow
on *:dialog:p2p:sclick:5: {
if (!%blocked) { amsg I have Blocked 0 | halt }
amsg I have blocked %blocked P2P's
on *:dialog:p2p:sclick:6: {
if (!$did(9).sel) { noop $input(You did not select a nick to remove,uwo,Error!) | halt }
write -dl $+ $did(9).sel p2pallow.txt
did -d $dname 9 $did(9).sel
on *:dialog:p2p:init:*: {
var %p2plist = 1
while (%p2plist <= $lines(p2pallow.txt)) {
did -a $dname 9 $read(p2pallow.txt,%p2plist))
inc %p2plist
on 1:open:?:*: {
var %p2pnick $nick
if (%p2pnick == $read(p2pallow.txt,w,%p2pnick)) { halt }
if (%p2p == on) {
if (%p2p != on) { halt }
inc -u30 $+(%,_p2p_lock,.,$nick)) 1
if ($($+(%,_p2p_lock,.,$nick),2) == 2) { close -m $nick | halt }
if ($($+(%,_p2p_lock,.,$nick),2) >= 6) { ignore -u30 $nick | close -m $nick | halt }
if (!$appactive) { flash }
inc %blocked
window @p2p Messages | echo -t @P2p $nick Messaged you on $server Saying: $1- at $time
write p2p.txt $nick Messaged you on $server saying $1- at $time
.msg $nick $nick This message is the %blocked Message to be blocked
beep 1 1
close -m $nick
on ^*:text:*:?:{
if (%p2pnick == $read(p2pallow.txt,w,%p2pnick)) && (!$appactive) {
beep 1 1 | flash
