Copy from a Kiwi chat window using your mouse
Move your mouse cursor to the left side of the text you want to copy. then, hold down the left mouse button and drag your mouse cursor across the text you want to copy, then let go of the mouse button.
The text you highlight WILL stay highlighted. Then you can click your right mouse button and select Copy. You’ll then have copied it.
To test this, copy some text using the method explained above, then move your cursor to the area in KiwiChat where you normally type. Then right click and select Paste and you should then see the copied text. Note: you can also Paste by holding down the Ctrl key and pressing V.
BACK to original message
