Administrators Koach Posted May 26, 2022 Administrators Report Share Posted May 26, 2022 Copy from KiwiChat using a laptop without a mouse Move your mouse cursor to the left side of the text you want to copy. Then, hold down the left button on your touchpad and slide your finger across the touch pad to highlight the text you want to copy, then let go of the touch pad button. The text you highlight WILL stay highlighted. Then you can click right touchpad button and select Copy. You’ll then have copied it. Note: you can also use Ctrl+C to copy the highlighted text. To test this, copy some text using the method explained above, then move your cursor to the area in KiwiChat where you normally type. Then click the right button on the touchpad and select Paste. You should then see the copied text. You can also Paste by holding down the Ctrl key and pressing V. BACK to original message Link to comment Share on other sites More sharing options...
